Experience Builder url
1518
02-07-2024 04:05 PM
elpinguino
Hi there, what's the difference between https://experience.arcgis.com/experience/<id> and https://experience.arcgis.com/<id>?
When I share the URL it asks the user (first one) to sign in to ArcGIS Online (fair), but then it takes them into the Experience Builder home page where you can select from any of the Experience Builders in the organisation, not the View published version of the Experience Builder. Should I be sharing the url differently? This is for a not tech savvy user so want to make it as simple and easy as possible.
Tags (1)
DanJiang
Hi @elpinguino ,
To share an app, the '/experience/' must be included in the URL. Otherwise there will be issues to load resources.
Here are some recommended ways to share the app. Please note that you need to publish the app first.
  • Copy the item URL from the dropdown menu in builder, or click "View published item" and copy the URL in the browser's address.
  • Copy the URL in the item detail page
  • Add a Share widget and copy the links from it
