Experience Builder unresponsive & crashing
4072
6
10-05-2021 08:41 AM
ScottHansen__MDP_
Beginning on October 5, 2021, I noticed that Experience Builder crashes and the application is unresponsive. If I edit the name of a chart or edit a charts style, the application becomes unresponsive and I receive a "page unresponsive" dialogue box. I made a duplicate of the application, which did not help. I also cleared Chrome's browser cache and restarted the machine, which did not help. Can ESRI Support check my file(s) to see if they are corrupted? Please see the image below.
AlixVezina
Hi @ScottHansen__MDP_ , I believe Esri Support will be able to help pinpoint the source of the issue. Please contact them directly for a quicker resolution: Esri Support | ArcGIS Technical Support
TonghuiMing
@ScottHansen__MDP_ After an initial investigation, it seems like a limitation with a small chart size. A workaround solution is to increase the size of the chart (you probably need to try several times and find out the threshold), it would probably solve the problem. Let us know if it works and we will continue to take a look at it.
ScottHansen__MDP_
Hello,
I used the blank template because I need the smaller charts to make room for the large map in the upper right-hand corner. Unfortunately, increasing the chart size is not a possibility.
RachealFarinloye
Any luck on why it was crashing?
ArianaMo1912
Were you able to find a solution? I am having the same issue with my experience
RachealFarinloye
What version of enterprise are you on? If no what version of AGOL are you on?
