Experience Builder Table Export Degree Character Changing
896
05-19-2025 06:08 AM
SophieSanders_24
Hello, I've build an experience builder with a feature service that has two fields with the coordinates in Degrees Minutes Seconds, e.g. DDD° MM' SSS.sss" <N|S|E|W>, These fields appear correctly in the pop ups and tables but when I export a csv table from the experience builder it changes to DDD° MM' SSS.sss" <N|S|E|W>,
I presume this is something to do with it being an unusual character but I cant seem to fix it,
When I export to csv table from ArcPro this does not happen so it is a problem in the experience builder export only,
Any help or suggestions appreciated
ShengdiZhang
Hi @SophieSanders_24 ,
The issue with the unexpected “A” character (e.g., seeing DDDA° instead of DDD°) is due to how the degree symbol is being interpreted by the system viewing the file. It’s a common encoding mismatch where special characters like ° aren’t displayed correctly.
We’ve identified the root cause and are working on a solution that ensures the file displays properly across different systems.
In the meantime, as a workaround, try opening the file using UTF-8 encoding. This should display the degree symbol correctly.
Shengdi
SophieSanders_24
Hello Shengdi,
Thank you for getting back to me, I tried the suggested and it worked, do you know when you expect the solution to be deployed?
best wishes,
Sophie
