Experience Builder Route Planning data action cannot be saved for Field Map navigation
63
yesterday
LeahGuo1
New Member
Hello,
I created an ArcGIS Online Experience Builder app.
My workflow is:
Select Features-->Plan Route-->Directions.
I enabled"Enable route saving" in Direction Widget. However, when route is generated by the Plan Route data action, I do not see the Save Route option.
I tested manually creating a route inside the Directions Widget, and the Save option works.
My goal is to send this planned route to ArcGIS Field  Map for navigation.
Is there a way to save a route created by the Plan Route action as a Route Layer, or is this a current limitation?
Thank you!
