Experience Builder - Related Tables and Feature Classes
1130
01-18-2025 01:09 PM
KateDoughty1
I am trying to using Experience Builder to visualize construction options. I have the following:
  1. Results feature class
  2. Construction segments feature class
  3. Construction options table
1 is/can be joined to 3 by ID
2 is/can be joined to 3 by ID
Essential what I want is for the user to filter by result, and for 2 and 3 to automatically update with the options.
I've tried arcade, pop-ups, etc. I really one result to show all available options based on the join, and the available options to only show construction segments based on the join.
Any help is appreciated!!
ShengdiZhang
Hi @KateDoughty1 ,
Due to some known limitations, currently, it is impossible to filter data from the Parent and Related tables simultaneously.
The message action Record selection changes - Framework - Filter data records, supports filtering related records, but you have to select a record on 1 to trigger the filter on 2 and 3.
Regards,
Shengdi
ShengdiZhang
Hi @KateDoughty1 ,
In the latest Feb 2026 AGOL release, we support selecting and filtering data records using the "Data filtering changes" trigger. This enhancement allows related layers to be filtered automatically when a filter is applied to the parent layer.
Please note that there is currently a limitation for performance considerations: the action will not run if the filtered results from the trigger data exceed 1,000 records.
Let me know if you have any questions or need further clarification.
Shengdi
