Experience Builder - Notebook WebTool
859
09-27-2024 01:34 PM
YS2388
I am attempting to achieve the following workflow:
1) There is a polygon layer in EXP application.
2) Select a group of polygons using the select widget.
3) Click the "Set as Analysis Input" button.
4) Select the custom web tool. (This web tool was created by publishing an AGOL notebook as a webtool).
5) After running the webtool in EXB, the output is a list of the objectID values of the selected polygons.
I have been able to publish a webtool and open it in EXB, but I am struggling to figure out how to create the desired output. Any help would be greatly appreciated.
Thank you
Wei_Ying
@YS2388 thanks for reaching out!
What parameter type you define for your output? for just showing a list of the IDs, you save your result as a "GPFeatureRecordSetLayer" or "GPRecordSet" so the result can be displayed in ExB Table widget. Or you can save your result as "GPDataFile" so you can output like .cvs, .excel, and the result as a file link will be available once the task complete.
