Experience Builder no longer able to support complex symbology?
510
7
2 weeks ago
MattCotterill
I recently overwrote a WFL from ArcGIS Pro, for an Experience Builder App and the complex symbology described in this previous post that used to be supported was downgraded. I've been overwriting with updates dozens of times over the last couple years with no issues. Any idea what's changed?
Thanks!
Ke_Xu
by Esri Regular Contributor
Hi @MattCotterill,
Does Map View show the same behavior?
Ke
MattCotterill
That's interesting, it looks as it should in Map View.
Ke_Xu
The display in Experience Builder (ExB) looks the same as in Map Viewer. Could you take a screenshot to show the difference?
Ke
MattCotterill
Sure, see attached.
Maybe I'm misunderstanding what you mean by Map Viewer. This screenshot is from the Web map I used in the Experience Builder App.
Matt
MattCotterill
Oh, that's very strange, it works now in ExB. It had been showing as thin, one-color diagonal lines on a white background. It seems fine now.
MattCotterill
For whatever it's worth, the overwrite when the issue began occurred on April 9th.
NicoleJohnson
MVP
For what it's worth, I checked out your app after you initially posted and everything looked the same to me, so I figured I just wasn't seeing whatever problem you were seeing.
Not sure if you tried clearing your cache but that seems to be the source of many problems (not sure about here though).
