Experience Builder: How to change arcgis js api version
2563
04-25-2024 11:39 PM
Saxina
I am using EXB dev edition version 1.12 which is currently pointing to the JS API version 4.27.
I would like to refer to the latest version 4.29 instead.
How can I achieve this?
Thanks
JeffreyThompson2
MVP Frequent Contributor
Did you run npm ci in the server and client folders?
GIS Developer
City of Arlington, Texas
JeffreyThompson2
https://developers.arcgis.com/experience-builder/guide/release-versions/
Each version of Experience Builder is built on the next version of the Javascript API. Upgrade to 1.14 and you will be using 4.29 of the API.
GIS Developer
Saxina
Hi @JeffreyThompson2
I tried the upgrade approach, I copied the app folder from 1.12 to 1.14. But the app I am working with contains custom widgets built with version 1.12. I am getting the issues below
JeffreyThompson2
GIS Developer
Saxina
I did run npm ci at /client and /server folders during the initial installation of version 1.14. But after I pasted my app folder from version 1.12, I did not run the command.
It is working now after running the command again.
Thanks, that solved my issue.
