ExB Dev Edition - Enterprise Login
8905
21
11-15-2023 12:55 PM
BrianLeroux
I have been running ExB dev edition 1.10 for a while and it works fine logging into my Enterprise portal. I am trying to move to ExB 1.13 now but after i set it up it will not let me log in using my enterprise portal URL. When I try it shows the loading icon and goes right back to the screen looking for a URL. I checked the Chrome debugger and I see the generate token go successfully. in the console I do see a message that states 'The user has not signed in'.
This very strange as I am doing nothing different in 1.10 vs 1.13. Any ideas?
Arne_Gelfert
Hey ESRI... any update on this? I don't know how you go from working products to broken products all the time. Installed 1.12 after enrolling in one of your EB classes. Now I upgrade to 1.13, and can't even finish the install/setup...so back to 1.12. This vicious cycle Bug/Bugfix/Bug is really the most annoying aspect of my job.
BrianLeroux
Hi. Any way to get an update on this bug? I am unable to find a way to subscribe to the bug to keep up to date.
JeffreyThompson2
MVP Frequent Contributor
I got an email this morning classifying this bug as officially fixed, which isn't exactly true. It will be fixed in Developer Edition 1.14 when it releases next week. If you would like to be alerted for updates on bugs or enhancements the easiest way is to call ESRI support and ask to track the progress.
GIS Developer
City of Arlington, Texas
Wei_Ying
Sorry for inconvenience. We do appreciate your feedback. This issue will be fixed in the coming 1.14 release (Mar.20).
Wei
BrianLeroux
Fantastic. Thank you!
KrichbaumHenry
Thanks for the update!
KrichbaumHenry
Confirmed this bug is now fixed in ExB dev edition 1.14! I am now able to log in with SSO.
RebeccaWatson1
I was just experiencing this same issue after upgrading to 1.15 exb and portal 11.3. I've just uninstalled 1.15 and gone back to 1.14 and it's working again. For now.
Wei_Ying
@RebeccaWatson1 thanks for your feedback. But I cannot reproduce the issue on my side.
Is your connected portal using Single-sign-on or other login configure like IWA?
RachappaBellappa1
Hi @WeiWei I am also having same issue with Exp Builder V1.15. I am using SSO to connect to  ArcGIS Portal, but what's happening is after signin it directs back to set-portal-url page.
In dev tools what's happening is it's failing in generatetoken where it's asking for credentials
