enable custom filter in the experience builder
3381
03-11-2024 08:27 AM
aawadrsk
Hello,
I am configuring an Experience Builder and I want to configure a filter widget and give the users the opportunity to create their own filter as we used to do in the Web Appbuilder. We used to just check the Enable custom filter box. is it possible to configure something like that in the Experience Builder?
Many Thanks,
Ali
JeffreyThompson2
MVP Frequent Contributor
There isn't really a way to allow a user to make arbitrary queries in a Filter Widget, but the List, Table, and Query Widgets have the Set Filter Data Action that allows for the user to make their own query.
GIS Developer
City of Arlington, Texas
MatthewSolomon
Is this for online? I do not see the Set Filter option for Enterprise 11.2.
JeffreyThompson2
This feature was added in Experience Builder 1.13. It will be added to Enterprise 11.3 which should be out very soon.
GIS Developer
Ke_Xu
by Esri Regular Contributor
Hi all,
Custom filters can now be set at run time with the Filter widget on November 2024 ArcGIS Online.
Please follow the steps below:
1. Add a Filter widget, click the New custom filter button to create a custom filter.
2. Select the data that you want users to use to make custom filters at run time. You can select multiple data sources.
3. Turn on Live view or Preview.
4. You could create the clause or clause set at run time.
Ke
