Embedded Survey123 only allowing one submission
2056
02-02-2024 05:05 AM
MikhaylaB
I have a survey123 embedded in an experience, and it only allows the user to submit one survey. I have to refresh the page to submit another, and the form is intended to be used to add multiple work orders. Is there a setting to refresh the survey without having to refresh the whole page?
JordanT
You can add a refresh interval to the element. this will consistently refresh the element after a certain amount of time. For example, below I added a refresh interval of 12 seconds or 0.2min to the element this will refresh it every 12 seconds more information on this setting can be found here
Jordan T
JordanT
Jordan T
MikhaylaB
That's awesome, thanks for the help.
MichaelGaigg
You can control this through the survey itself:
MikhaylaB
Is that an option if I've created the survey in connect?
