Elevation Profile configuration for small screen - how to show Select Line and Draw Profile side-by-side
2504
12
09-05-2025 12:33 PM
AdamGebhart
I am working on an app that will include the Elevation Profile widget in Developer 1.18.  I can get the widget configured as desired for the large and medium screen configurations.  I am not able to set it correctly on the small screen though.
I have it in the bottom sidebar while the map and everything else are in the top sidebar.
This is my medium configuration.  You can see Select Line and Draw Profile are side-by-side.
I want the small screen to look like this too if possible, but no matter what style configuration combos I come up with I can't.  Even if I am able to get them stacked and visible there is always part of the Select Line option cut off and the scroll bar on the right doesn't allow for scrolling all the way to the top.
I've changed the style configs for the Elevation Profile and Sidebar (bottom) about every way I can and only increasing the height of the sidebar seem to make it better, but that takes up too much screen space.
Is there a way to display them next to each other or at least get the scroll bar to work all the way?
Any help is appreciated.
AdamGebhart
@AlixVezina should 'not' in your post be 'now'?  I received an email from Support the other day indicating this bug (000179668) has been fixed.
AlixVezina
Haha I'm sorry, yes it should be " This issue should now be fixed"... thanks for checking!
AdamGebhart
@AlixVezina That's what I figured.  Thank you.
