'Dynamic' URL to zoom/locate features
2885
02-28-2022 01:47 PM
Badeschlapfen
Hi there,
I'm still not sure if this is possible with Experience Builder...
I would like to have a link from a database item to an experience builder app using a 'dynamic' URL.
Clicking the URL in the database item should open a new window, load the experience builder app and zoom to the related feature.
I know this is possible in the WebApp Builder by using "?find=
http://<your portal url>/apps/webappviewer/index.html?find=380 new york street, redlands, ca
In the experience builder apps, this does not work anymore...
I think you can use "?data_id=". However, the ID is not really user-friendly.
Eg: https://experience.arcgis.com/experience/5947e2d55c1846e1b4952851aa97efe8/page/page_5/?data_id=dataS...
?data_id=dataSource_1-Fun_5299%3 is referring to a layer, while A13 is the actual item...
I find this quite frustrating. There should be a much easier way. Is there one??
Tags (3)
MarcoPoetsch
I would love to see a solution for this!
Can someone explain the URL parameters?
HeathAnderson
I know we have waiting for this feature for quite some time.  In fact, we have not fully moved to the new map and experience builder because of this missing function.  I spoken with an individual from ESRI and they told me "friendly" URLs should coming to Experience builder in early 2024 (I am hoping sometime in Q1 of 2024).  I also assume their statement meant, the functionality will come to ArcGIS Online in 2024 but, I am not sure when it will be available in Enterprise.
Best,
Heath
DavidForbuss1
I'm still having to use the webapp builder maps for some applications because I can't get this to work on exp. builder yet.  Really need it to work the same with the ?find= functionality.
DavidForbuss1
Just figured out this can be done in an instant app, which is what I ended up doing...using the same base webmap that is operating in my exp builder.  You can set a custom parameter, and carry it over from your third party software.  At that point you can dig into the search settings and adjust the behavior further:
In this case I just added '&taxlot=[number passed in from other software]' to the end of my link.
