Developer Edition 1.12 Client Install Error
3540
6
07-06-2023 06:40 PM
LeonAus
I am trying to install Developer Edition 1.12 and the client install is failing with:
4426 verbose stack FetchError: request to https://olympus.esri.com/artifactory/api/npm/npm-repo/@arcgis/core/-/core-4.27.2.tgz failed, reason: getaddrinfo ENOTFOUND olympus.esri.com
4426 verbose stack     at ClientRequest.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:130:14)
4426 verbose stack     at ClientRequest.emit (node:events:513:28)
4426 verbose stack     at TLSSocket.socketErrorListener (node:_http_client:502:9)
4426 verbose stack     at TLSSocket.emit (node:events:525:35)
4426 verbose stack     at emitErrorNT (node:internal/streams/destroy:151:8)
4426 verbose stack     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
4426 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
4427 verbose cwd C:\Program Files\ArcGIS\ArcGISExperienceBuilder\client
4428 verbose Windows_NT 10.0.17763
4429 verbose node v18.15.0
4430 verbose npm  v9.5.0
4431 error code ENOTFOUND
4432 error syscall getaddrinfo
4433 error errno ENOTFOUND
4434 error network request to https://olympus.esri.com/artifactory/api/npm/npm-repo/@arcgis/core/-/core-4.27.2.tgz failed, reason: getaddrinfo ENOTFOUND olympus.esri.com
4435 error network This is a problem related to network connectivity.
4435 error network In most cases you are behind a proxy or have bad network settings.
4435 error network
4435 error network If you are behind a proxy, please make sure that the
4435 error network 'proxy' config is set properly.  See: 'npm help config'
Is there something I am doing wrong or is this a problem in the version?
Jianxia
@LeonAus @AndyWells @JeffreyThompson2 an updated download file for dev edition 1.12, which addressed the client install error, is now available on the developers website. Thank you all!
JeffreyThompson2
MVP Frequent Contributor
Getting the same error.
GIS Developer
City of Arlington, Texas
AndyWells
Same problem here. Can't install or run it.
JeffreyThompson2
I think I may have stumbled on a solution. I think ESRI may have moved the file location for arcgis/core. I was able to get it straight from npm. Try:
npm i @ArcGIS/core
npm i
npm start
GIS Developer
AndyWells
Hey, I appreciate this. It worked for me. Thanks.
Jianxia
@LeonAus @AndyWells @JeffreyThompson2, thanks for letting us know the install issue. We are working on it and plan to deploy a new download file Monday (July10)  morning around 7 Pacific Time if not earlier. We will keep you posted.
Jianxia
