Customize existing widgets
493
08-28-2024 04:29 AM
JasonBOCQUET
Hi community,
I want to modify the existing filter widget but i'm encountering a problem.
in the "widget.tsx" file there is this code who manage the position of the reset filter button :
showResetAtBottom = (resetAll, arrangeType, wrap, filterItems): boolean => {
    let atBottom = true
    if (
      resetAll && arrangeType === FilterArrangeType.Inline && !wrap &&
      (filterItems.length > 1 || (filterItems.length === 1 && getShownClauseNumberByExpression(filterItems[0].sqlExprObj) === 0))
      atBottom = false
    return atBottom
  getItemUseDs = (item: filterItemConfig) => {
    let useDs = item.useDataSources[0]
    if (item.isGroup && item.sqlExprObjForGroup) {
      useDs = item.useDataSources.filter(ds => ds.dataSourceId === item.sqlExprObjForGroup[0].dataSourceId)[0]
    return useDs
  getFilterItems = (config, arrangeType = FilterArrangeType.Block, wrap = false, isPopup = false) => {
    const showResetAtBottom = this.showResetAtBottom(config.resetAll, arrangeType, wrap, config.filterItems)
    return (
      <div className={classNames('w-100 h-100 d-flex justify-content-between',
        showResetAtBottom ? 'flex-column' : 'flex-row')}
        css={getStyles(this.props.theme, this.props.config)}>
        <div
          className={classNames('w-100 filter-items-container',
            arrangeType && config.arrangeType === FilterArrangeType.Inline ? 'filter-items-inline' : '',
            wrap ? 'filter-items-wrap' : '', isPopup ? 'filter-items-popup' : '')}
          {(this.state.filterItems as unknown as filterItemConfig[]).map((item, index) => {
            const useDs = this.getItemUseDs(item)
            const ds = this.isDataSourceRemoved(useDs.dataSourceId) ? null : this.state.dataSources[useDs.dataSourceId]
            const isNotReadyFromWidget = this.state.outputDataSourceIsNotReady[useDs.dataSourceId]
            return (
              <FilterItem
                key={index} id={index} widgetId={this.props.id} intl={this.props.intl}
                selectedDs={ds} useDataSource={useDs}
                isNotReadyFromWidget={isNotReadyFromWidget} logicalOperator={config.logicalOperator} config={item}
                arrangeType={arrangeType} triggerType={config.triggerType} wrap={wrap} omitInternalStyle={config.omitInternalStyle} filterNum={this.state.filterItems.length}
                onChange={this.onFilterItemChange} itemBgColor={this.props.theme.ref.palette.neutral[400]} theme={this.props.theme}
        </div>
          config.resetAll && <div className={classNames('filter-reset-container', showResetAtBottom ? 'bottom-reset' : 'right-reset')}>
            <Button icon type='default' size='default' className='reset-button'
              style={{ borderRadius: config.triggerType === FilterTriggerType.Toggle ? '16px' : null }}
              title={this.props.intl.formatMessage({ id: 'resetAllFilters', defaultMessage: jimuUIMessages.resetAllFilters })}
              aria-label={this.props.intl.formatMessage({ id: 'resetAllFilters', defaultMessage: jimuUIMessages.resetAllFilters })}
              onClick={this.onResetChange}
              <ResetOutlined />
            </Button>
          </div>
      </div>
My question here is simple : how can I move the button to integrate on the filter dialog box ? I don't want to have this button outside of the dialog box because it consume to much space if I use multiple filter widget.
