custom widget: recommended way to pass data from action to widget.tsx
3264
11-10-2021 05:01 PM
john_cartwright_noaa
Hello All,
I have a custom widget which is listening for a Message (e.g. DataSourceFilterChangeMessage). The logic for handling the message is in an implementation of AbstractMessageAction in the src/actions folder.  What is the recommend way to pass data captured in theAbstractMessageAction#onExecute method out to the src/runtime/widget.tsx?
Thanks!
--john
I've settled on an approach of publishing the value to the widget's store w/in the Action, e.g.
getAppStore().dispatch(appActions.widgetStatePropChange(this.widgetId, 'queryString', queryString));
and then retrieving it in the widget.tsx via the props.stateProps, e.g.
<h2>{props.stateProps.queryString}</h2>
If anyone has a better suggestion, I'd be glad to hear it.
--john
--john
RobertScheitlin__GISP
@john_cartwright_noaa
I am not really sure how you are resolving "props.stateProps.queryString" in your widget. I don't see "stateProps" in the widgets props object.
This is how I am doing it (not saying that this is necessary better).
Sending Widget :
this.props.dispatch(appActions.widgetStatePropChange(this.props.id, 'pSearchData', cTextElements));
Receiving Widget:
interface ExtraProps{
  pSearchData: any
export default class Widget extends React.PureComponent<AllWidgetProps<IMConfig> & ExtraProps, State>{
  static mapExtraStateProps = (state: IMState, ownProps: AllWidgetProps<IMConfig>): ExtraProps => {
    let wId: string;
    for (const [key, value] of Object.entries(state.widgetsState)) {
      if(value.pSearchData){
        wId = key;
    return {
      pSearchData: state.widgetsState[wId]?.pSearchData
//Then else where in the widget code I use the extra prop
this.props.pSearchData
