I'm trying to make a custom draggable window to show on my map. I've created this widget:
import React, { useState } from 'react';
import { Rnd } from 'react-rnd';
import { DownDoubleOutlined } from 'jimu-icons/outlined/directional/down-double';
import { CloseOutlined } from 'jimu-icons/outlined/editor/close';
const DraggableResizableComponent = () => {
const [showOptions, setShowOptions] = useState(false);
return (
<Rnd
default={{
x: 100,
y: 100,
width: 320,
height: 200,
minWidth={200}
minHeight={120}
maxHeight={400}
maxWidth={300}
dragHandleClassName="draggable-header"
bounds="window"
style={{
backgroundColor: 'rgba(128, 128, 128, 0.5)',
border: '1px solid #ccc',
borderRadius: '4px',
enableResizing={{
bottomRight: true,
bottom: false,
bottomLeft: false,
left: false,
right: false,
top: false,
topLeft: false,
topRight: false,
<div
className="draggable-header"
style={{
display: 'flex',
justifyContent: 'space-between',
alignItems: 'center',
padding: '12px',
backgroundColor: '#000',
color: '#fff',
borderBottom: '1px solid #ccc',
marginTop: '5px',
position: 'relative',
<div style={{ display: 'flex', alignItems: 'center', gap: '10px', position: 'absolute', right: '10px', top: '50%', transform: 'translateY(-50%)' }}>
<div
onClick={() => setShowOptions(!showOptions)}
style={{ cursor: 'pointer', position: 'relative', top: "-2px"}}
<DownDoubleOutlined size="m" color="#fff" />
{showOptions && (
<div
style={{
top: '24px',
right: '0',
backgroundColor: '#fff',
color: '#000',
zIndex: 1000,
minWidth: '120px',
<div
style={{ padding: '8px', cursor: 'pointer' }}
onClick={() => {
console.log('Opção 1');
setShowOptions(false);
Opção 1
</div>
<div
onClick={() => {
console.log('Opção 2');
Opção 2
</div>
</div>
</div>
<CloseOutlined size="m" color="#fff" onClick={() => console.log('Close Window')} />
</div>
</div>
<div style={{ padding: '10px' }}>
Content
</div>
</Rnd>
export default DraggableResizableComponent;
The problem is when i try to put this on the map. the Drag is being restricted by the widget area and i want it to behave like the Widget Controller Window, that can be moved arround all the app.
How can i acheive this? I've tried to put in a higher hierarchy on DOM but no sucess.
I guess this may be restricted by the "react-rnd" lib. Jimu has a draggable component https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-index-drag... could you check whether you can use it?
Thank you for reply.
I tested and it has the same behavior, Only movable on the widget area =/
Have you tried the "bounds" property?
Yep. Line 23, i tested changing to app div but also, no success.
Try building this test application:
Try adding a canCrossLayoutBoundary: true to the properties in the manifest.json.
This property is false by default, and it allows content inside the widget across the widget boundary.
