configuring triggers and actions relating to the filter/list widget and the map widget in Experience Builder
1155
10-18-2024 06:49 AM
JonathanHall3
I want the user to filter the items in a list widget using the filter widget, and then for the map to adjust to the current extent of the results of the filter, so that the filtered items are shown on the map/map just zooms towards the filtered items.  I gather a trigger and action needs to be applied, but I'm not sure which order they need applying and to which widgets.
ShengdiZhang
Hi @JonathanHall3 ,
I suggest adding the following message action to the list widget:
Data filtering changes - Map - Zoom to.
If you configure multiple message actions to a widget, the order will only matter if there is a conflict between the actions.
Let me know if you have any other questions.
Regards,
Shengdi
