Configuring Feature report widget
178
07-03-2026 08:49 AM
LouiseHarris1
Hi
I have built an Experience builder app and in this I have a map widget, a survey123 widget and feature report widget. I have configured the Map and survey widgets so that when you select a feature on the map the information collected in the survey is displayed in the form in the survey widget, both have the same source data - the hosted feature layer, for my survey, in the web map. I cannot configure the report widget so that when a feature is selected on the map it generates a report for it. It doesn't seem to recognise when a feature has been selected on the map. I can't use the same data source as the map and survey widget because in order to choose the 'work with survey option' and select the report template I have created the data source has to be hosted view layer _form.  Map and Survey widgets use the hosted feature layer - CoAPR 2025-2026, the report widget uses the hosted view layer -  CoAPR 2025-2026_form. How can I get the report widget to work?
