Chart Widget shows all data when opening up the experience
1112
06-12-2024 06:44 AM
TaliaSmithSickler
I have created an ArcGIS Experience builder web app using related data and tables connected to a Chart Widget and a List Widget through Target Actions. When clicking on a name, the chart changes the data and the table changes it's data. These actions are working well, however, when the app is initially opened, the Chart shows all of the data at once, and it is very confusing for a user to see all of the data at once on the chart. Is there an option to have the Chart Widget only show data that has been filtered through a target action? The target actions don't select data in the table, but they do filter the data in the table widget.
Wei_Ying
Hi @TaliaSmithSickler ,
Do you use "Selected feature" view in Chart data? And you can also specify the data view when no selection is made. With this workflow, you should be able to see chart as expected.
Wei
