Can't see survey widget in layout
1198
07-20-2021 08:45 PM
elpinguino
Hi EB community,
I've been having issues on and off with the survey widget. Has anyone tried putting a survey in a section/view? Any issues?
I have survey widgets in a section and then a view within the section. I drag the widget into the view. I can see it in the outline on the left hand of the EB screen. I can also see what survey I've selected, how I want it displayed and what attributes to pass in the panel on the right. I can't see it in the EB layout though, which is where I need it to be.
Screenshot below to show what I mean.
Has anyone else had this issue? Is it a bug where survey widget doesn't work properly in views or sections? I notice I don't have this issue when I put it by itself in a blank layout.
elpinguino
Thanks Francisco. Do you ever have the issue of your form widget not appearing in the published ExB? not form the builder end?
