Can't download Developer app. I've never experienced this.
1875
10
11-05-2025 12:34 PM
AdamGebhart
I just attempted to download and deploy an app to our local server and got the following message.  I am in Developer 1.18 and have used a few older versions and never seen this until today.
I am wondering if this is related to a recent update of my PC from Windows 10 to 11.  The reason I say that is I have successfully downloaded and deployed two different 1.18 apps prior to the Windows update.
Has anyone else seen this and know how to fix it?
JeffreyThompson2
MVP Frequent Contributor
Yes, I think that is the problem. Did you download after the update on Oct 23? Themes were re-designed in the last update to something incompatible with the older version of Themes. And the entire application would be a version ahead of your Developer Edition.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
I don't know what's going on. The first thing I would try is running the Command Prompts in Admin mode.
GIS Developer
AdamGebhart
I ran that as an administrator and still failed.  I did notice this in the command prompt window.
I don't recall ever deleting that folder and I don't see the same folder being in 1.17 or 1.16.
JeffreyThompson2
This error suggests you created a custom Theme called Master at some point and then removed it. Or didn't migrate it when you updated Experience Builder. Things to try:
  • Add the Master Theme back to the your-extensions/themes folder with the client server off, then start the client server.
  • If you don't want to use this Theme anymore, check all your projects Themes and set them to something other than Master.
GIS Developer
AdamGebhart
@JeffreyThompson2
Hmmm, I looked back at all the versions of ExB I've downloaded or used before (1.10, 1.11, 1.14 - 1.18) and none of them have the Master folder.
This specific app is one I built in ArcGIS Online then imported into Developer.  (This was the first time I've tried that workflow).  Do you think there is a chance it's related to that?
JeffreyThompson2
GIS Developer
AdamGebhart
Yes, that's exactly what I did.  Normally I just test things out in AGO, then build everything new in Developer.
I suppose I'll test out a new Developer app in a little bit and see if I can download it.
JeffreyThompson2
Wait a few weeks for Developer Edition 1.19 to come out. It should be compatible with the version currently in ArcGIS Online.
GIS Developer
AdamGebhart
Unfortunately this app needs to be published before Developer 1.19 is released, so I have to just build all new in Develooper.  It won't take too long though but I really wish I would have done it all in Developer to start.
Thanks for the suggestions.
AdamGebhart
@JeffreyThompson2  I finished building the app in Developer 1.18 and was able to download it.  I marked your comment about that as the solution.  Thanks.
