Blurry Bookmark Widget Images
2109
05-08-2024 08:03 AM
DJ_GIS
I am working on an Experience Builder application that includes a web scene with the Bookmark widget that has been added to a section view. I am using the Gallery template and have the widget set to pull the bookmarks associated with the web scene. The Experience Builder application is being built in 1920 x 1080.
No matter what I have tried the thumbnail images for the bookmarks are blurry. The blurry thumbnails appear in Experience Builder, Experience Builder Live View, Experience Preview and on the published Experience Builder application.
So far I have tried the following:
  1. Recreated the bookmarks in the web scene with the scene Optimize 3D graphics set to full Quality.
  2.  Adjusted the size of the widget in Experience Builder (want to further note that if the option is available the sizes are all based on percentage).
  3. Updated the widget template
  4. Added the Widget Controller and included the Bookmarks Widget.
  5. Added the widget outside of the section view.
None of the above steps have yielded non-blurry bookmark thumbnails.
Any help or suggestions would be greatly appreciated.
TonghuiMing
Hello @DJ_GIS
Thanks for bringing this up!
Per my colleague's investigation, this behavior was introduced when you created the bookmarks in the Scene Viewer. The pictures in the Scene Viewer bookmark are generated & stored with a small size of 114*62 px, thus, they look blurry in any other larger-sized containers.
If you create bookmarks inside ExB directly the thumbnails won't be affected. Or it might be helpful to reach out to the Scene Viewer team and see if they see this as a potential enhancement. Hope that could help.
DJ_GIS
Hello @TonghuiMing
Thank you for the response. Unfortunately I do not believe creating the bookmarks in ExB would work.
Current workflow involves creating 360VR scenes from the web scene bookmarks with the web scenes being used to supplement the 360VR scenes. With this, it is crucial that the bookmarks match.
Out of curiosity, are there any options available to automatically create consistent bookmarks in ExB and a web scene?
Thank you
Thomas1
Hi @TonghuiMing,
We have the same problem with the blurry thumbnails. Creating bookmarks inside ExB directly doesn't cover the same possiblilities as bookmarks in the web scene such as changing the background map, showing shadows at different time of the day...
