Batch Editing Showing Time for Date Time Fields Meant to be Hidden
171
Tuesday
GarekNorpoth1
I am currently using Experience Builder Dev Edition 1.20 and have been configuring an Edit Widget with the new batch editing capability. I have a layer with an edit form configured where I have Date Time fields set to only display the date. Within Experience Builder, I have the widget set to display a subset of fields as opposed to using the layer settings. When I have the Date Time field outside of a group in the edit form, it displays as expected in Experience Builder. However, if I put the field within a group in the form, the time dropdown appears in Experience Builder. Is there something I am missing with this or is this a bug? Attached is a picture of my edit form and one of the Date Time fields in question, and then another of what it looks like in Experience Builder when batch editing.
TanuHoque
@GarekNorpoth1
I can't help you with your original question as I'm not an expert in ExB. That being said, it is just an FYI in case it in your workflows. If your workflows requires only to store/display 'dates' (without time parts), then we recommend you to use 'DateOnly' field type, instead of 'Date' field type.
Pls let me know if you have any question.
Refs:
