Attribute Table: Set the "Select Mode" to Single for all layers that users add
646
02-05-2025 08:19 AM
ericsamson_tract
Currently, the set select mode to single or multiple has to be set on individual sheets. This is a bit frustrating, because the default selection is multiple. Often times users will add dynamic layers to the table through the use of the app, and then when they click on individual records, they end up selecting multiple records when they only want to look at the records one at a time.
Is there a way to set the default for all sheets to be single selection? I'm using developer edition, so I can make the change if I need to dig into the code.
