ArcGIS Portal 11.3 Connecting trigger for Map and Graph that filters
333
06-08-2026 05:07 AM
pbDudley
Hello. I am trying to learn Experience Builder in Portal 11.3. Im having trouble connecting a trigger to filter a graph based on data that I select in my map. Even some of the other triggers are tricky for me to figure out. Do you all know of a good tutorial on here or youtube?  Or perhaps someone can outline the steps for this so I can try?
Thank you
pbDudley
Ok, I have it to where I click on the graph it filters the map for these records. But I'm more interested in selecting the features on the map to have it filter the graph. When I go to the map, then action, I only see the table available. I dont see my graph. Can it not filter this way?
ShengdiZhang
Hi @pbDudley ,
You can choose the target "Framework". When you apply the filter to data / framework, all widgets using that data will be filtered.
Shengdi
