ArcGIS Experience Builder Near Me widget- calculate intersection area for each of the sublayers with the created buffer area and export results to PDF
653
01-28-2025 08:42 AM
kronezone
Add the ability to calculate the intersection area for each of the sub layers with the created buffer area, and export/print these results as a PDF. Currently, the user is only be able to configure the analysis to display the intersection area for the layer as a whole, not within each sub-layer. Several Esri Support Services representatives have also tested this workflow with multiple grouped layers with sublayers within it and were also unable to calculate the areas intersecting the buffer for each sub-layer. This functionality is essential in order to match the functionality of the Screening widget in WAB. Until then, my team is unable to transition fully from WAB to ExB.
