ArcGIS Experience Builder 1.1 custom widget Editor display data layout.
4080
10
10-09-2020 09:06 AM
SunilTerkar
I have copied the Editor widget from GitHub and put under client "your-extensions" directory. Editor widget is based on ArcGIS JavaScript library 4.X and expected to display data like here:
Edit features with the Editor widget | ArcGIS API for JavaScript 4.17
See image for reference
But I am getting Editor widget without scroll window Experience Builder, to display the data I have to stretch the window.
Has anybody experience same issue or do I need to edit the code. I assume its layout issue.
See image for reference.
Regards,
Sunil Terkar
DavidMartinez
@PhilLarkin1 @SunilTerkar  we updated the sample editor widget to use the scroll just like the JS API widget. You can find it here. https://github.com/Esri/arcgis-experience-builder-sdk-resources/tree/master/samples/widgets/editor
Cheers,
David
