Select tool on map widget improvement
789
10-19-2023 11:09 AM
Status: Open
AngelaSchirck
Since EB Developers ed. 1.12 does not have a select widget that can be customized, it would be nice if the select tool on the map widget would allow the following:
1) Pick which select tools you want (maybe you don't need lasso or line e.g.)
2) Default to "on" and "point" selection (and why is that point selector so freaking big!! Make it smaller.)
3) Have the "circle" tool show the radius of the circle as you drag it (customizable to desired units).
4) Have the "rectangle" tool show the dimensions of the rectangle as you draw (customizable to desired units).
