It would be helpful in arcgis online either as a widget in Experience builder/instant apps OR this ability in Map viewer:
1. the ability to export the line from the elevation profile to my content with the elevation data connected to it.
2. the ability to upload/add a line feature and get an elevation profile for the line.
you wrote in the summer
"WIth the upcoming June update, you'll be able to export the profile line to your Content with the attached profile statistics. This will create a feature collection item that you can then publish as a hosted feature layer"
"For the ability to upload/add a line feature and get an elevation profile for the line, we're looking into supporting this in the following update before the end of this year."
were either of these implemented? because I do not see an option to export in the elevation profile widget in a map scene
thanks!
With the upcoming June update, you'll be able to export the profile line to your Content with the attached profile statistics. This will create a feature collection item that you can then publish as a hosted feature layer
To do this, you can connect another widget to the Elevation profile statistics output data source and use the Export to item action. This will export the profile line segment along with its statistics.
For this, you need to enable the Select from added layers option and upload a line to the map using the Add Data widget. You'll be able to select the line added using the Add Data widget with the Elevation Profile Select line tool.
