Disable editing for specific fields in Editor widget
892
04-13-2026 12:29 PM
Status: Open
Bud
Legendary Contributor
In an Editor widget in Experience Builder, I want to see all fields, but restrict editing to certain fields.
For example, with a Survey123 feature layer in Experience Builder, I want users to see all fields, but only edit the STATUS field, not any of the others.
As far as I can tell, there isn't a way to restrict field editing for specific fields in Experience Builder or in a web map. Could that functionality be added?
Related:
4 Comments
KenBuja
You can make a field uneditable in a web map by using the Form editor.
Neal_t_k
Not sure if this follow through to EB.  In AGOL go to the data tab, click fields, select the field you want to restrict.
Bud
As @KenBuja mentioned, this can be done in the web map > form editor:
DougBrowning
Changing these editable settings in a Form does not block them from simply editing in the attribute table or in Pro.  Or open the service in a new map and edit.  Only safe way now is a database view.
More info here plus a script to turn them off  https://community.esri.com/t5/arcgis-online-questions/turning-off-editing-field-by-field/m-p/1695946...
