Issue Addressed List for June 2023 release of Experience Builder in ArcGIS Online
Subscribe
3273
06-30-2023 01:51 PM
BUG-000132489 The Directions widget in ArcGIS Web AppBuilder hangs and does not work if Arcade expressions are added to a feature layer as a search source.
BUG-000137318 Experience Builder: Feature Info widget does not correspond with the selected feature in the map.
BUG-000141103 The extent sync of two map widgets are not at the same scale level
BUG-000147501 The 'Disable scroll zooming' option in the Map widget is still working in ArcGIS Experience Builder.
BUG-000150593 The Filter widget in ArcGIS Experience Builder does not show the complete list of unique values for a field when the web map is symbolized using unique values from another field.
BUG-000152901 When sorting is enabled in the List widget in ArcGIS Experience Builder, incorrect information is displayed in the Feature Info widget.
BUG-000153416 Query Widget for Draw Graphic buffered features result in ArcGIS Experience Builder being inconsistent when exported to CSV file.
BUG-000153546 The 'Pan to' and 'Zoom to' actions do not work when both are applied to a secondary map in ArcGIS Experience Builder.
BUG-000154423 Unable to select map image layers in ArcGIS Experience Builder if the layer is above any tile layers.
BUG-000154743 Inconsistent behavior in ArcGIS Online Experience Builder when performing an action to trigger zooming synchronization between map frames.
BUG-000154824 The auto-refresh parameter on a layer is not functional when the webmap is integrated into ArcGIS Experience Builder (AGOL).
BUG-000154856 Exporting a form to the Table widget in ArcGIS Experience Builder does not honor the field settings applied in ArcGIS Online.
BUG-000156501 Fixed Panel widgets aligned to the top of a Web Experience using the Foldable template in the configuration view do not have the same pixel height when seen in the preview view within ArcGIS Experience Builder.
BUG-000156590 Search widget (when embedded in the Widget Controller widget) in ArcGIS Experience Builder has an issue: when clicking on the search bar of the Search widget window, the recent searches list appears behind the Search widget window.
BUG-000156865 ArcGIS Experience Builder Draw widget perimeter measurements are incorrect when drawing a polygon.
BUG-000156900 Search: include candidateFields for geocoders
BUG-000159128 Experience Builder Survey widget is failing to pass through polygon and polyline geometry to the survey. (June 2023 Release Related)
BUG-000159156 Embedded ArcGIS Experience Builder persistently loads if using SAML authentication following the ArcGIS Online June 2023 update
BUG-000159177 After June 2023 release, certain widgets (Views Navigation/Fixed Panel) are throwing error "Cannot read properties of undefined" when switching between auto and custom layout for small screen sizes in ArcGIS Experience Builder.
BUG-000159226 The error “only support esri geometry / geojson / xlsForm geometry” occurs in the survey widget in the Experience Builder when point data is collected on an existing feature service with RD New projection
BUG-000159238 Experience Builder Data pane adds only the first 10 layers of a hosted feature service published from a File Geodatabase containing more than 10 layers
BUG-000159266 Filters applied to Enterprise Map Service in ArcGIS Online web map are not honored in Experience Builder.
BUG-000159290 Incorrect area showing if the map questions from the survey are set to hide in ArcGIS Experience Builder after the June update 2023.
BUG-000159319 After the June 2023 release, filters applied to a map layer through the Data pane display correctly in the edit mode of an ArcGIS Experience Builder experience, but do not display when selecting Preview or 'View published item'.
BUG-000159369 Table widget with data set as Bar chart statistics output does not get updated when filtered in Experience Builder.
BUG-000159402 Features are not filtered when applying a filter on a pie chart in Experience Builder based on a field that has mismatched displayed and coded values
ENH-000137021 Adding an image custom icon to a widget in ArcGIS Experience Builder 2.1 Developer Edition/Online results in an accessibility error stating that the image does not have ALT-TEXT.
ENH-000137122 Improve the accessibility of the Views Navigation widget in Experience Builder
ENH-000137774 Include the option to display legend items in the Map Layers widget in Experience Builder
ENH-000148737 Requesting to add a BaseMap Gallery widget in Experience Builder.
ENH-000153403 Missing tooltip for some of the Map widget tools
ENH-000154017 Request for a Swipe widget in ArcGIS Experience Builder, with similar functionality to current Swipe widget in ArcGIS Web AppBuilder
ENH-000154136 Provide the ability to have Accessibility for all in Experience Builder.
ENH-000154353 Add the ability to modify the alignment of the title and the content in the Feature Info widget in ArcGIS Experience Builder.
ENH-000154954 Rotate/tilt trigger in map widgets in ArcGIS Experience Builder for syncing 3D scenes
ENH-000155337 Provide the ability to navigate the Feature-Info-widget in ArcGIS Experience Builder using a keyboard.
