Which VM select when I install ArcGIS Enterprise in Azure
2930
03-14-2019 12:00 PM
DiegoLlamas
Hello,
I will use Cloud builder to deploy ArcGIS enterprise in Azure. there are several vm we can select to do the installation and I would like to know which one is the best VM to select and do not break the license agreement for 4 cores that i can use for ArcGIS Server.
Which one do you recommend or have used?
Regards,
Diego Llamas
TXDPSProduction
Diego, Did you find any guidance on recommended VM sizes for each element of Enterprise?
DiegoLlamas
Hello,
Yes, at the end of this URL have some suggestions Deploy ArcGIS Enterprise on Microsoft Azure—ArcGIS Enterprise | ArcGIS Enterprise
But we have used the Standard DS12 V2 4 cores, 28 ram it has worked fine with our installation.
