which is better to run arcgis server on?
2834
03-13-2018 12:06 PM
ChrisDistler
Linux or Windows server?
AdrianWelsh
MVP Honored Contributor
Chris,
This will likely depend on many outside factors, like what are you looking for, what platform do you have set up already, what are you (or your IT group) familiar with, etc.
Here is a thread that discusses some pros/cons here:
Linux versus windows ArcGIS install
You also need to consider what backend database you will be using. Some minor discussion of that is here:
https://community.esri.com/thread/187778-what-is-the-best-database-for-arcgis-oracle-postgres-sql-se...
