webgisdr - mixed Linux/Win Environment
960
07-27-2020 06:44 AM
danbecker
Enterprise 10.8, Server is installed on Win Server 2012. Portal and Datastore are installed on seperate Ubuntu 18.04 machines. I get an error that the Win (ArcGIS Server) machine can't access the BACKUP_LOCATION path I specified, obviously because it's in a Linux format. All machines can reach the BACKUP_LOCATION, but I need to specify it using 2 formats...tricky.
Any work around for this? I just want to run the webgisdr tool to clear out the portal logs so I can get rid of that nag in the Portal log.
thanks.
danbecker
Does anyone know if a mixture of operating systems is supported for each component?
Linux Machines: (ArcGIS Datastore, ArcGIS Portal)
Windows Machines (ArcGIS Server)
how would we specify "SHARED_LOCATION" parameter in this case?
