VM Migration ArcGIS Server
529
05-18-2024 02:44 AM
Wade
Because the operating system needs to be upgraded, a new VM is currently being built. Then my new VM needs to reinstall ArcGIS Server.
I would like to ask if it is possible to copy all published services from the old VM to the new VM to reduce the migration time.
MichaelVolz
Esteemed Contributor
Has your organization tried in place upgrades of servers?  If you try this hopefully you at least have a development environment to try it first.
Wade
The reason why the server is not directly upgraded is that the old and new hardware are located in different locations, and due to operating system licensing reasons, only new VMs can be created for migration processing.
A_Wyn_Jones
Hi @Wade,
You can use the export site function in ArcGIS Server to do this:
https://developers.arcgis.com/rest/enterprise-administration/server/exportsite.htm
https://enterprise.arcgis.com/en/server/latest/administer/windows/back-up-and-restore-your-arcgis-se...
Keep in mind what's not included and use WebGISDr if you're migrating a Enterprise solution. Before importing this to your new VM/Server installation - I would suggest you register the data locations first to ensure your Server is properly communicating with the data sources.
A
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
BillFox
MVP Frequent Contributor
