Versions des services Esri
3437
09-18-2015 02:20 AM
AntoineAudusseau
Bonjour,
J'aurais aimé savoir si les services Esri (Map Service, Feature Service, ...) possèdent leurs propres cycle de versionnement ou est-ce qu'ils suivent les versions d'ArcGIS for Server ?
Y a-t-il des différences fonctionnelles entre les différentes versions ?
Merci d'avance,
DerekLaw
Esri Esteemed Contributor
Hi Antonie,
The different web services in ArcGIS Server (e.g., map service, feature service, locator service, etc.) do NOT have different release cycles from Server. They are released in the same cycle as the ArcGIS for Server software release.
And yes, there may be functional differences in web services between ArcGIS for Server software release cycles. For example, we added enhancements to the map service from v10.2 to v10.3. It is best to review the What's New help topic in the ArcGIS for Server help documentation.
Hope this helps,
AntoineAudusseau
Thank you very much
