Hi Team,
We have recently upgraded ArcGIS Enterprise from version 11.3 to 11.4. Previously, our deployment was using PostgreSQL version 12, which was compatible with 11.3. However, with the new upgrade to 11.4, PostgreSQL 12 is no longer supported.
To ensure compatibility and continued stability, we now need to upgrade the PostgreSQL version to 15 or later version.
I would appreciate your assistance in upgrading the PostgreSQL.
Thanks & Regards,
Kristofer
Hi Kristofer,
Yep, you're spot on — PostgreSQL 12 isn’t supported with ArcGIS Enterprise 11.4, so upgrading to version 15 (or later) is definitely the right move.
I’d recommend spinning up a test instance of PostgreSQL 15 first, just so we can validate everything before touching production. We can use pg_dump/pg_restore or pg_upgrade depending on how things are set up.
Once the data is migrated, we’ll need to update the database connections in ArcGIS Server and Portal and run the Upgrade Geodatabase tool in ArcGIS Pro to make sure everything checks out.
Happy to help coordinate or walk through the steps if needed.
Regards,
Venkat
@VenkataKondepati , @Kristofer , @George_Thompson
If you have PG 12 geodatabases, then you can attempt to upgrade the PG instance from PG 12 to PG 15.
But, if you have PG 11 geodatabases, then read the information below carefully.
How To: Upgrade to PostgreSQL 12.x if the Database Contains a Geodatabase
Procedure:
Using pg_dump/pg_restore for upgrades to PostgreSQL 12
There are several options for creating backups of PostgreSQL databases. However, for PostgreSQL databases used to store geodatabases, Esri recommends you use pg_dump to create an archive file, drop the database, re-create the database with the same name, and restore to the re-created database using pg_restore. This backup and restore methodology can be used before or after upgrading the geodatabase to ArcGIS version 10.8.1 or ArcGIS Pro 2.6. You can upgrade directly from a 10.6.x, 10.7.x, or 10.8 geodatabase if your database is at a supported release for ArcGIS Pro 2.6 or ArcGIS 10.8.1.
I have included the information about this in my community.esri.com white paper.
How to Move the PostgreSQL Enterprise Geodatabase with pg_dump and pg_restore
After the migration, we also need to upgrade the PostGIS extension.
How to Upgrade the PostgreSQL and PostGIS version for the Ent. Geodatabase on Windows
How to Upgrade the PostgreSQL and PostGIS version for the Ent. Geodatabase on Linux
For more best practices, visit my community.esri.com blog.
Mapping and Charting Solutions (MCS) Enterprise Databases Best Practices
System Requirements
https://enterprise.arcgis.com/en/system-requirements/latest/windows/database-requirements-postgresql...
Question: So I am using the pgdump utility from a PG 12.x (or later) to dump the database from the PG 11.x geodatabase?
Answer: Yes, you must, see below the reason. In your case you will use pg_dump 15 version.
IMPORTANT:
Problem: pg-10 dump fail to restore on pg-12
"pg_restore: warning: restoring tables WITH OIDS is not supported anymore"
Solution: create the dump again using pg-12 and try to restore again
--pg-10-5438 --> pg-14-5437
/usr/pgsql-14/bin/pg_dump --version
/usr/pgsql-14/bin/pg_dump -h mondblnxpg -U postgres -p 5438 -F c -b -W -f /mnt/nfs/redarchive4/db_bkp_active_yes/mondblnxpg1/pg_5414/agmgdbpg/agmgdbpg_06_27_2025_070000.bkp agmgdbpg
pwd: *****
pg_dump: warning: WITH OIDS isnot supported anymore (table "i10")
Recommended Upgrade Steps to avoid breaking ArcGIS Server Services
I hope this clarifies.
Here is a good blog from @MarceloMarques : https://community.esri.com/t5/mapping-and-charting-enterprise-databases/how-to-upgrade-the-postgresq...
Hi @VenkataKondepati @George_Thompson @MarceloMarques ,
Thanks for the quick response and Support !!
Thanks & Regards,
Kristofer
