Unable to complete operation. Error executing tool DBSCAN_CLUSTER
1450
01-30-2023 01:46 AM
DimasPutrapangestu
hi
i have problem executing my tools in REST API. When I create tools and I run on the desktop, the tools work. However, when I published the service and I tried to execute it, an error appeared. Can anyone help?
import arcpy
import pandas as pd
from math import radians, cos, sin, asin, sqrt
from sklearn.cluster import DBSCAN
from scipy.spatial.distance import pdist, squareform
import matplotlib.pyplot as plt
import numpy as np
if __name__ == "__main__":
    arcpy.env.overwriteOutput = True
    in_file = arcpy.GetParameterAsText(0)
    output = arcpy.GetParameterAsText(1)
    epsilon = float(arcpy.GetParameterAsText(2))
    min_sample = int(arcpy.GetParameterAsText(3))
    #Convert the feature class to a pandas DataFrame
    array = arcpy.da.FeatureClassToNumPyArray(in_file, ["SHAPE@X", "SHAPE@Y"])
    df = pd.DataFrame(array)
    #Extract the X and Y coordinates from the DataFrame
    coords = df[["SHAPE@X", "SHAPE@Y"]].values
    #Get the spatial reference of the input feature class
    describe = arcpy.Describe(in_file)
    #create spatial object
    SR = describe.spatialReference
    #Create a spatial reference object
    SR = arcpy.SpatialReference(SR.FactoryCode)
    def haversine(lonlat1, lonlat20) :
    # convert decimal degrees to radians
        lat1, lon1 = lonlat1
        lat2, lon2 = lonlat2
        lon1, lat1, lon2, lat2 = map(radians, [lon1, lat1, lon2, lat2])
    # haversine formula
        dlon = lon2 - lon1
        dlat = lat2 - lat1
        a = sin(dlat/2)**2 + cos(lat1) * cos(lat2) * sin(dlon/2)**2
        b = 2 * asin(sqrt(a))
        r = 6371 # Radius of earth in kilometers. Use 3956 for miles
        return (b * r) * 1000
    distance_meter = squareform(pdist(coords, (lambda u,v: haversine(u,v))))
    arcpy.AddMessage(epsilon)
    arcpy.AddMessage(min_sample)
    #Function DBSCAN
    db = DBSCAN(eps=epsilon, min_samples=min_sample, metric='precomputed').fit(distance_meter)
    y_db = db.fit_predict(distance_meter)
    #visualization of db_scan
    plt.scatter(distance_meter[:,0],distance_meter[:,1],c= db.labels_)
    plt.xlabel("X")
    plt.ylabel("Y")
    plt.title("Grafik Data compound DBscan")
    plt.show
    print("Jumlah Kluster:{}".format(len(set(db.labels_[np.where(db.labels_!=-1)]))))
    print(db.labels_)
    labels = db.labels_
    #Export feature class
    out = arcpy.da.NumPyArrayToFeatureClass(array, output, ["SHAPE@X", "SHAPE@Y"],spatial_reference=SR)
    #Add field cluster into feature class output
    cluster = arcpy.AddField_management(output,"CLUSTER","Short")
    with arcpy.da.UpdateCursor(output,["CLUSTER"]) as cusor:
        for i, row in enumerate(cusor) :
            row[0] = labels[i]
            cusor.updateRow (row)
