Table to Domain failed Error 999999 on enterprise geodatabase
793
11-22-2024 01:07 AM
yockee
I try to export an XLSX / CSV file to Domain using Table to Domain GP tool.
I get "Error:999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.". It worked fine yesterday. I have been doing this many times and this is the first time its happening.
Then I try it on another SDE Geodatabase just to make sure. The Domain is created succesfully.  Then I use this domain and copy-paste it manually to the other server that was failed. It is a success.
Both geodabatases are using Postgres 16.
What might be the cause of Table to Domain GP tool failure on one server ? How do I check an alternative error message because the default error message is not helpfull ?
