Synchronize with two-way replica fails : Table already exists
2228
03-21-2013 08:16 AM
IB1
Why is nothing working?
I have an SDE geodatabase which has all versioned data.
I created a geodata service from this geodatabase.
I then created a two-way replica from server into another SDE geodatabase using the geodata service.
When I make an edit on the child replica and try to synchronize it back, I get this error:
[ATTACH=CONFIG]22841[/ATTACH]
Sychronize Replica Failed
What is this even talking about?
I'm using ArcGIS Desktop 10.1, ArcGIS for Server 10.1, SQL 2012 and I have the 2008 R2 Native client.
I really need this to work.
ShaunWeston
Is this the same issue you're having:
http://forums.arcgis.com/threads/71323-Replication-Sync-Error-Table-Already-Exists
Seems to be an issue on SQL Server 2012.
IB1
Yeah, seems to be the same. But it sounds like using the 2008 R2 native client solved the problem in that thread.
I'm using the 2008 client, but am still having the problem.
Pretty disappointing.
nicogis
IanBroad2
see http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDg3NzY1
The link doesn't work. It ask me to login and then takes me right back to the login page again.
Seems to be some bugs in the website.
nicogis
