Subset Map Services Fail to Start After Migration to a new Azure tenant using WEBGISDR
552
03-03-2026 05:06 AM
AhmadAwada1
I have an ArcGIS Enterprise deployment consisting of two machines that I recently migrated from one Microsoft Azure tenant to another (same region). Following the migration, approximately 20% of the map services are failing to start in the new tenant environment.
Environment Details
  • Two-machine ArcGIS Enterprise deployment
  • No high availability configured
  • Same Azure VM sizes in both tenants
  • Migration performed using the WebGISDR tool
  • WebGISDR restore completed successfully (100% success reported)
  • Same Public URL (Webcontext URL being used)
Issue Description
  • A subset of map services with referenced SDE data sources (Azure SQL) are failing.
  • Hosted services are functioning normally.
  • Some map services using the same SDE data source are working correctly, while others are not. This suggests the issue may not be related to database connectivity or firewall configuration.
Errors Observed
When accessing the affected services through REST:
  • 0x80004005 – No Layer or Table was initialized
    (in "esriCarto.GraphicFeatureServer")
Occasionally:
  • Error handling service request: java.util.concurrent.TimeoutException
Additional Notes
  • The affected services are configured to use shared instances, and I am unable to change them to dedicated instances.
  • I am unable to stop or delete the impacted services from either Portal (delete item) or ArcGIS Server Manager.
  • I cannot overwrite the failing services.
  • However, I am able to successfully publish a new service (with a different name) using the same APRX and data source.
Given that:
  • WebGISDR restore reported full success,
  • VM sizes and region are unchanged,
  • Some services using the same data source work correctly,
I would appreciate guidance on what could cause partial service initialization failure after tenant migration, particularly for referenced SDE services running in shared instance mode.
TanuHoque
@AhmadAwada1
this requires further investigation by our analysts. Would you mind reach out to Esri Support? And they will be help you resolve this issue.
Thank you.
DanNarsavage_IDWR
I'm seeing some similar behavior in our on-prem installation.  @AhmadAwada1 could you share any tips on how you solved your issue? Thank you!
AhmadAwada1
As far as I remember, i went into ArcGIS rest admin -> services  and then started the services from there. I remember they were in a stopped configured state.
