Store credentials with service item missing - Adding feature service from arcgis server 10.7.1 to Enterprise 10.9.1
1875
01-15-2025 08:21 AM
Thomas_Puthusserry
Trying to add a feature service from standalone GIS server 10.7.1 to enterprise portal 10.9.1. There is a built-in user account created in server 10.7.1 to access the secured service.
In enterprise 10.9.1, the option Store credentials with service item. Do not prompt for authentication is missing. Can add the item with built-in user credentials, but asks to login every time the item is accessed. This deployment is not disconnected.
But, the store credential with service option is available when added to enterprise portal in 11.1 (this is a different deployment and network).
Looked at this post: Solved: When does the option "store credentials with item"... - Esri Community, but our deployments are not disconnected.
Also seen this article: Problem: Unable to Store Credentials with a Secured Service Item in Portal for ArcGIS However this is working fine in 11.1 without any SSL import so expect same in 10.9.1 as well.
TimoT
Hi @Thomas_Puthusserry
The issue may still be SSL/TLS related, even if you never imported SSL certificates in 11.1. There are too many unknown variables for us to rule it out just yet.
A good test is to use the CheckUrl function in the ArcGIS Portal Directory:
  1. On your 10.9.1 Portal, go to ArcGIS Portal Directory (e.g. https://portal.domain.com/portal/sharing/rest).
  2. Log in with Administrator credentials.
  3. Navigate to Home > Portals > CheckUrl.
  4. Enter the URL of your secure service and click CheckUrl. Share the results.
If the response is anything other than a HTTP 200 status, it may indicate an issue with your 10.9.1 Portal's ability to verify the service's SSL/TLS certificate chain.
On a related note, it will be worth checking if you have restricted the portal's proxy capability
Run these tests and checks on both your 10.9.1 and 11.1 deployments to compare results.
jschuckert
@TimoT , I have a case where all the sudden a secured service no longer works. In a newer Enterprise environment (11.3) it works fine and allows the ability to store credentials, however in 10.9.1 no longer does. The environment is fully patched with all the latest.
Running your test, I see my Enterprise is unable to validate the SSL cert. Both my environment and the source environment (where the secured service is coming from) check out as valid on their SSL certs checking dates and online tools.
Any suggestions?
