Stage Utility Network Error
1299
02-01-2019 07:11 AM
SSMIC3038
Working thru the Utility Network tutorials and trying to stage the water package, have worked up thru the entire process successfully and I'm now trying to stage the utility network and  I'm getting "error 001991: Operation is only supported on the Default version".
The database in question (SQL 2016) only has the default version, no other versions exist. dbo is version owner. I am connecting as named user and can make other data successfully outside this process.
Any help is appreciated
SSMIC3038
The geodatabase connection has to be set to branch versioning.
SSMIC3038
