[SOLVED] PublishingTools error: "Unable to instantiate class for xml schema type: ProjectedCoordinateSystem"
3125
07-13-2017 01:32 PM
SteveMcCullough
We are setting up a fresh install of Arc Server 10.3 on Linux (in order to migrate from a 10.3 install on an old windows server). We cannot publish any services, either by exporting from Arc Map or by uploading exported service definitions.
The error in the logs reads "Unable to instantiate class for xml schema type: ProjectedCoordinateSystem"
Which results in good old "ERROR 001362: Failed to extract manifest from uploaded service definition. Failed to execute (Publish Service Definition)."
Help?
SteveMcCullough
UPDATE
I was using a stock install of Debian without LSB. Installing LSB solved this.
SteveMcCullough
UPDATE
