SOAP API not honoring the Java http.nonProxyHosts system property
937
04-21-2013 06:35 PM
ShaunForbes
When using a proxy via the http.proxyHost setting it looks like the SOAP API in 10.1 ignores any servers listed using the http.nonProxyHosts list and tries to send the requests via the proxy anyway.
This worked correctly with earlier versions on the SOAP API (I've tested and confirmed it works as expected with 9.3, not sure with 10.0).
Has anyone else seen this? Or can confirm if I'm correct.
Shaun
UPDATE: Looks like this is fixed in SP1.
