Sharing spatiotemporal big data store hosted feature layers
2023
11-03-2023 07:52 AM
LeeBrannon1
I just created a distributed collaboration between Enterprise Portal (11.1) and our ArcGIS Online organization and have had success sharing items from our Portal to ArcGIS Online.
But, with our  hosted feature layers from spatiotemporal big data store, the collaboration does not work.  Instead of having a seamless sharing experience, ArcGIS Online prompts for authentication for spatiotemporal big data store hosted feature layers.
I am hoping for a "simple" way around this, for a seamless sharing experience (no authentication needed) with ArcGIS Online members that includes spatiotemporal big data store hosted feature layers.
JakeSkinner
Esri Esteemed Contributor
Hi @LeeBrannon1,
I don't believe Spatiotemporal Feature Services are supported with Distributed Collaboration in which the service will be distributed as a 'copy'.  A feature service requires Sync enabled for the data to be copied, and I don't think there is a way to enable Sync on a Spatiotemporal Feature Service.
JakeSkinner
Hi @LeeBrannon1,
LeeBrannon1
Thanks @JakeSkinner.  Have to admit, I didn't pay much attention to whether or not I had an option to enable Sync.  And yes, I was trying to share it as a copy, but now I am wondering if sharing as a 'reference' is an option for those hosted feature layers and if it would make any difference towards access.
Guess I should check on that as a next step.
LeeBrannon1
After subsequent testing of sharing by reference and by copy, I am finally convinced that, indeed, it is not supported, as @JakeSkinner noted.  Not successful with any of the tests I performed.   Bummer.
