Server error in ArcGIS Web Adapter "ESRI.ArcGIS.ADF.Core, Version=10.0.0.0"
3631
10-11-2012 12:35 AM
VytenisZilevicius
After installing Arcgis Web Adapter (IIS) for ArcGIS Server 10.1 I get the following error:
"Could not load file or assembply 'ESRI.ArcGIS.ADF.Core, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
I would appreciate any help on this issue.
RandallWilliams
Is the ArcGIS Server 10.0 web ADF application builder installed on the same website on this machine? It sounds like there may be a conflict between the ADF/Server Manager application builder and the web adaptor.
VytenisZilevicius
Hmm, I guess it is installed on the same machine. How could I check this? I had ArcGIS 10.0 previous installation on this machine. Is it possible that I have left anything uninstalled?
Thanks.
EricKriener
Thanks.
Anybody ever figure out how to fix this?
nicogis
you can use PatchFinder to determine which ArcGIS products are installed: http://support.esri.com/en/downloads/patches-servicepacks/view/productid/66/metaid/1876 in How to identify which Service Pack is installed
