Server and geodatabase on separate machines
1691
08-02-2013 07:54 AM
ChrisMathers
Can I install an enterprise geodatabase on a server that doesn't have ArcGIS Server on it? Right now we have one server with our geodatabase on it along with our AGS site but want to move to a multi-server setup. We want to have an editing geodatabase on one server and a second server with our production geodatabase and our AGS site. Its kind of a nasty point of failure that we are finally fixing.
EDIT: Its an enterprise GDB on SQL now and the other will be as well after the we stand the second server up.
JakeSkinner
Esri Esteemed Contributor
Hi Chris,
Yes, this won't be a problem.  Once both geodatabases are up and running, you could set up geodatabase replication so that the two geodatabases are easily synced.
JakeSkinner
Hi Chris,
