SELinux Blocking ip from read/open on libjsig.so
2087
05-21-2019 09:12 AM
BenRomlein
I'm running ArcGIS Server 10.7 on RHEL Server 7.6
Whenever I start ArcGIS Server with the systemd unit included in the install, copied from arcgis/server/framework/etc/scripts/ to /etc/systemd/system/arcgisserver.service, it gives SELinux alerts blocking read/open on libjsig.so and libprejsig.so.
When I start ArcGIS Server by directly calling startserver.sh, There are no alerts.
I have attempted to install local policy allowing access using audit2allow via this guide: https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/6/html/security-enhanced_linu...
and also in the RHEL SELinux Troubleshooter instructions:
# ausearch -c 'ip' --raw | audit2allow -M my-ip
# semodule -i my-ip.
I've also tried adjusting the file's context with:
# semanage fcontext -a -t default_t libjsig.so
# restorecon -v libjsig.so
How can I start ArcGIS Server through systemd without the SELinux permission errors?
EarlMedina
Hi there,
I assume you want SELinux to remain enabled and probably don't want it in permissive mode. If so, then I think the other other option would be to make an exception for the process by flagging it with the unconfined option. I'm not 100% positive on what the proper place to configure that would be. Possibly you would just throw this line into the systemd service itself:
SELinuxContext=system_u:system_r:unconfined_t:s0
BenRomlein
Thanks, Earl.
I tried adding that line to my unit file in various places but none have yet solved the problem.
Adding it in the [Unit] or [Install] Section, the service can start successfully, but SELinux still alerts about libjsig.so.
Adding it to the [Service] Section, starting the service fails with SELinux denying transition on the startserver.sh script.
Is there a specific order the lines in my unit file have to be arranged?
Here are the current contents of the file:
sudo cat /etc/systemd/system/arcgisserver.service :
# ArcGIS Server systemd unit file
# Configure ArcGIS Server to be started at boot on Linux distributions
# adopting systemd init system (For example RHEL 7.x and SuSE12) by
# following these instructions:
# 1.) Switch to the root user.
# 2.) Copy this file to /etc/systemd/system
# 3.) Enable the service to start at boot:
# # systemctl enable arcgisserver.service
# 4.) Verify systemd service is setup correctly:
# # systemctl stop arcgisserver.service
# # systemctl start arcgisserver.service
# # systemctl status arcgisserver.service
# 5.) Reboot the system and verify that Server restarts properly.
[Unit]
Description=ArcGIS Server Service
After=network.target
[Service]
Type=forking
User=igsgis
GuessMainPID=false
# The minimum number of processes need to be set to 25059 or higher. Enable
# and raise this limit if it is a heavily used system. Use ulimit -Su -Hu to
# check current values.
# LimitNPROC=25059
# LimitNOFILE=65535
# To prevent any one service from spawning too many threads and consuming all
# server resources, systemd v228 and beyond included in SLES12 SP2 and higher
# set the maximum number of threads to be created at 512. Users on SLES12 may
# need to enable and raise this limit if it is a heavily used system. Use
# "systemctl show --property DefaultTasksMax" to check the current value. To
# find the version of systemd, use "systemctl --version".
# TasksMax=512
ExecStart=/diskarray/arcgis/server/startserver.sh
ExecStop=/diskarray/arcgis/server/stopserver.sh
[Install]
WantedBy=multi-user.target
Thanks again for your help.
EDIT:
This is the output of ls -Z for the two files throwing the error:
-rwx------. igsgis data unconfined_u:object_r:unlabeled_t:s0 libjsig.so
-rwx------. igsgis data unconfined_u:object_r:unlabeled_t:s0 libprejsig.so
(As mentioned earlier, I've tried switching context type to default as well, I've also tried switching user from unconfined to system)
The SELinux Alerts are:
SELinux is preventing /usr/sbin/ip from open access on the file /diskarray/arcgis/server/framework/runtime/jre/lib/libprejsig.so.
SELinux is preventing /usr/sbin/ip from getattr access on the file /diskarray/arcgis/server/framework/runtime/jre/lib/libjsig.so.
